Re: Wacky Idea?
Posted by Brownie450 on July 15, 2007 at 16:58:49 from (207.177.82.208):
In Reply to: Wacky Idea? posted by Goose on July 15, 2007 at 16:18:59:
Your Delco will fit. Use a length of threaded rod[3/8 usually works]. You may want to turn the mounting bracket upside down, & lengthen the holes as needed. You may need a shorter belt. Make a different tightener by hinging 2 pieces of flat 1/4 or 5/16 steel to the correct length with holes at each end [one on gen, & one to engine]. Tighten belt , & lock all bolts on tightener bracket.
