Farmall Tractors Discussion Board
Re: 706 reverse gear
Posted by Wayne on December 08, 1998 at 16:26:23:
In Reply to: 706 reverse gear posted by Dan Mcfatridge on December 08, 1998 at 12:32:19:
I have an 806 that is the same way. Mine has the old style shifter placed some bushings on the shifter shaft to keep shifter from wobbling. this helped quite a bit. but it can still bother. tried to adjust linkage by 1/4 turn increments Then I could get reverse and no high. but if I idle the engine way down It will work 85% of the time.
Post a Followup
: Re: Re: 706 reverse gear
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
