Re: What good is an H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten on February 10, 2000 at 11:32:56 from (206.175.72.226):
In Reply to: What good is an H posted by Mark on February 10, 2000 at 08:24:36:
Mark,
Correct me if I'm wrong, but I thought the 140 had the same C123 engine as the Super C/130/200.
The H has the C152 engine and it's rated at 25 HP on the drawbar. The 200 is rated at 22 ?HP on the drawbar and I think the 140 was pretty close to that too. The difference is weight. The H is several hundred pounds heavier than the 140 and can better transfer the HP to the ground. If both Hs have 3-points on them, buy them both and sell the extra 3-point. It'll probably bring $300 if it's any good and that will be a big chunk of what you will probably pay for both tractors. Then the second H can be a parts tractor or you could restore them both. This would be especially nice if they were consecutive S/Ns.
Good luck whatever you decide to do,
Phil
Post A Followup
: Re: Re: What good is an H
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
