Re: m farmall with low oile pressure
Posted by Janicholson on July 16, 2007 at 10:32:53 from (199.17.6.122):
In Reply to: m farmall with low oile pressure posted by Bob Tedford on July 14, 2007 at 19:27:22:
Interactive Even contested intellegence) is not uncommon on forums. We all need to be civil, but free discussion is good. The pressure in your lube system should be 10psi at Idle hot. If it is above that, and not knocking, things should be OK. I would use 15-40 Rotella, or RPM Delo oil in the tractor to see if it makes a difference. The cover plate on the oil pumps have been shown to be a problem, and can be sanded flat on a plate glass surface with 200 silicon carbide paper followed by 400 grit to polish. Use non directional even pressure to flatten the cover. The end clearance on the pump should be between .0008 and .001 The gaskets are very thin, and used as a shim to adjust this clearance. If I took off the pan and found no issue with the oil pump, then I would plastigauge the mains and rods (.001-.003 are fine More is bad) Try the oil thing first, then the pump, then the bearings in that order. JimN
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
