Re: Sloppy woodruff key on 400 camshaft
Posted by D Slater on July 16, 2007 at 18:05:13 from (71.164.58.156):
In Reply to: Sloppy woodruff key on 400 camshaft posted by SDE on July 16, 2007 at 16:18:32:
You may not have anything to do this with but I have had good luck shaping a oversize key to fit in worn cam. Usualy only one side of cam and keyway is worn so you can figure out where the center lineup is. Try to get cam and gear back in same relationship. If the cam is not out of engine watch and don't push cam back when installing gear. Recommend it be out or have a pusher that screws on front of cam. Sometimes cam gear needs key slot straightend up first before sizing key. Takes time ,trial and error to fit everything tight. If cam has the original right hand threads for cam nut, stake nut to threads after tight. Don't know how far into production your 400 is so if your cam gear # ends with DB instead DA, The DB was machined with a smaller diameter on ID for tighter fit to cam so I would recommend supporting cam behind first cam bearing surface when installing.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
