Re: Warning Diode for 12v conversion
Posted by Bob on July 16, 2007 at 22:08:04 from (69.178.229.154):
In Reply to: Warning Diode for 12v conversion posted by Wisconsin_Joe on July 16, 2007 at 21:43:41:
I'm "Bob", NOT BobM.
I just looked at BobM's #6 diagram, and there clearly IS a wire from the "run" terminal on the ignition switch, through an "idiot light", to the alternator's #1 "switched excite" terminal.
The diagram is labeled "6 -Farmall Super H/M 12 volt Delco 10-SI alternator conversion". Are we looking at the same diagram?
If you decide to use a diode INSTEAD of an "idiot light", yes, diodes are polarity-sensitive. The cathode end, usually marked by a white band, goes towards the alternator's #1 terminnal, like THIS:
