Re: carburetor trouble; more info
Posted by Janicholson on July 17, 2007 at 08:09:38 from (66.173.50.139):
In Reply to: carburetor trouble; more info posted by chadd on July 16, 2007 at 15:53:25:
Sorry no one seems to know. Most are dedicated to a particular carb (some exceptions, but different passages flow differently. Trying it is harmless unless it runs lean and heats from it, or runs rich and carbons up, but the feel of the tractor should tell you if there is an issue JimN
