Re: 1954 SH ammeter.
Posted by Janicholson on July 17, 2007 at 11:57:52 from (66.173.50.67):
In Reply to: Re: 1954 SH ammeter. posted by GordoSD on July 17, 2007 at 10:03:35:
If it a new (under warrantee) VR, get a new one. If it is yours, open it and look at the 2 0r 3 relay like coils in there. one of them will be wrapped with mighty heavy wire, and heavy duty contacts, that is the cutout relay. ignore it. If there are two other relays, one of those will have a heavy winding and smaller contacts. Ignore it. The only one left is the voltage relay and it usually has a double set of small contacts. That one is the one to adjust. one pair of the relay contacts will be held closed when the tractor is off. Usually the upper ones. There is a spring that tensions this set closed (the little flipper controling the contacts will be away from the coil) this spring will need to have just a tiny bit more tension placed on it (screw, or bent tab) this is a very fine adjustment, and is not course at all. Check charging voltage after the tiny adjustment, and redo if not at about 7 volts. JimN
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
