Re: 656 PTO lever leaking fluid.
Posted by Owen Aaland on July 17, 2007 at 14:42:25 from (65.165.246.40):
In Reply to: 656 PTO lever leaking fluid. posted by Scott(MO) on July 16, 2007 at 19:00:06:
The shaft seal is the only thing that keeps the oil from leaking. Make sure the stem is not rusted or scored. You will need to reset the pressure after replacing the seal. The valve assembly must come out the bottom but you can replace the seal from the top. Check back to 07/11/07 to see a simular discussion dealing with a 756. You have the same type of PTO.
