Re: 300U not running well
Posted by RustyFarmall on July 18, 2007 at 05:50:54 from (66.43.253.26):
In Reply to: 300U not running well posted by 300Randy on July 18, 2007 at 05:25:30:
Most likely you need to clean the sediment bowl, but the problem might also be in the screen in the fuel inlet fitting on the carburetor. Another possibility is a foreign object in the gas tank which occasionally finds its way over the fuel outlet, and restricts the flow of fuel. And last, a faulty ignition coil can cause the same exact symptoms.
