Re: farmall H 45 belly pump what type of fluid?
Posted by Dave_Id on July 18, 2007 at 16:27:58 from (70.112.233.145):
In Reply to: farmall H 45 belly pump what type of fluid? posted by lekander883 on July 18, 2007 at 15:45:35:
The manual says 30w. It"s heavier because the tolerances are not as tight as newer hydraulic systems. If you are using hydraulic implements that you will be using on other tractors, then use Hytrans hydraulic oil. You don"t want to cross contaminate the oil. There is supposed to be a dipstick attached to the filler cap, but may no longer be attached. I can"t tell you how much it takes, check your manual.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
