Re: Re: Re: Re: Re: Speed reduction gear for Farmall M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Wardner on February 10, 2000 at 15:19:44 from (63.23.216.112):
In Reply to: Re: Re: Re: Re: Speed reduction gear for Farmall M posted by Jim on February 10, 2000 at 14:31:47:
It is clear that most of the transmission parts between the M and MTA are not interchangeable. However, the MTA parts book lists the mainshaft (with differential pinion) as fitting M and SM.
It is also clear that the M differential and ring gear will fit all M size tractors through 660. I think that there is a good possibility that 560 differential ratios might fit any M. The limiting factor is the main shaft and it would have to be visually compared. That could be done at any good tractor salvage yard.
Post A Followup
: Re: Re: Re: Re: Re: Re: Speed reduction gear for Farmall M
