Re: Loader changeover to hyd.bucket and down pressure
Posted by Fromjb2 on July 18, 2007 at 19:28:49 from (74.101.67.211):
In Reply to: Loader changeover to hyd.bucket and down pressure posted by r bond on July 18, 2007 at 13:47:11:
Hi Ron, I have experience with 434 with IH 1500 loader with hydraulic bucket, no down pressure on lift arms then traded for 384 with IH 1550 loader with hydraulic bucket and double acting cylinders on lift arms.
If your tractor already has an aux remote outlet then you can do it the cheap way but 3pt CANNOT be operated at same time as loader.
Proper way is to re-route the high pressure line out of the hydraulic pump to the inlet of the loader spool valves, then outlet of spool valves to high pressure inlet of 3pt system in front of seat then dump outlet of spool valves to T that goes into 3pt filler plug behind the seat.
If I had a picture it would be easier.
Hope this helps.
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
