Re: farmall 6 volt starter
Posted by Randy in NE on July 19, 2007 at 06:02:10 from (204.124.193.192):
In Reply to: farmall 6 volt starter posted by michael geer on July 19, 2007 at 05:47:42:
Have you checked your battery cables? You need a good set of 0 or 1 gauge wires with GOOD connections for a 6 volt system. Make sure that the ground has a good connection. Have you taken the starter to an electrical repair shop and have them test it? If you did the work yourself and accidentally shorted something out inside the starter then that could be your problem. A few minutes at a repair shop can save you a lot of time and headaches.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
