Re: farmall 6 volt starter
Posted by old on July 19, 2007 at 07:30:53 from (4.244.186.193):
In Reply to: farmall 6 volt starter posted by michael geer on July 19, 2007 at 05:47:42:
Any time you open a starter up you need to replace more then just the brushes you need to also replace the bushings or yep you will have that type of problem. What happens is now that you opened it up things have moved just a little so its not worn in the same as before so things now bind. I would open it up again and replace the bushings and also doube check the brush springs
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
