Evaluating Farmall H 12volt conversion
Posted by Wisconsin_Joe on July 20, 2007 at 01:14:31 from (66.82.9.64):
I"ll try to describe the wiring situation as best I can. If you flip the turn-off (not original of course)switch over it has 4 terminals the top two are the (run/on) position the bottom two terminals are jumpered to each other and are the (stop/off) position. The bottom left(stop/off)terminal has a wire coming from the push starter where the positive battery cable is attached. The bottom left then jumpers to the bottom right terminal. When I turn the switch to the "on" position both the top left and top right terminals become energized. The top left terminal has the warning "idiot light" wire and the top right terminal is wired to the coil and supplies power to a voltmeter. There is no jumper between the top terminals and I noticed the idiot light wire that runs to post #1 on the alternator is disconnected and dangling by the alternator. My first question is how do I handle the idiot light wire on the alternator because of the switch setup? Should the idiot light wire be moved over to the right side to the coil and voltmeter terminal. Obviously some one disconnected this from the alternator for a reason. The other thing I noticed is that there is another wire coming directly from the push starter where the positive battery cable is attached and runs directly to the alternator bat terminal. Just wondered if that was ok. Hope this makes sense, I am not well versed in this yet. Thanks as always
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
