Re: Hole in left bell housing with a plug - 140 ?
Posted by Haas on July 20, 2007 at 10:13:09 from (12.65.42.22):
In Reply to: Hole in left bell housing with a plug - 140 ? posted by NawlensGator on July 20, 2007 at 10:02:38:
The hole is for access to lube the clutch release bearing. Look at your owners manual page 75, item 22 in the lube chart. Does not need much grease. Even if you use the tractor a lot, once a year is enough. The manual says every 250 hrs.
