Re: W 9 waterpump
Posted by Roger in Iowa on July 20, 2007 at 13:36:25 from (69.18.26.74):
In Reply to: W 9 waterpump posted by Barnheater on July 19, 2007 at 13:46:58:
The rotation difference is an idler in the drive train from the crank to the magneto/distributor drive that is a part of the drive train for a W9 but not an M.
With the radiator cap removed and the water level plumb full, do you get bubbles when it is running. W9's were nortorious for cracked heads. Won't leak into the crankcase, but into the radiator from the combustion chamber.
Good luck
Roger in Iowa
