Re: farmall super c high altitude pistons
Posted by El Toro on July 20, 2007 at 15:08:14 from (205.188.117.137):
In Reply to: farmall super c high altitude pistons posted by farmall50 on July 20, 2007 at 11:38:08:
I would doubt if it has high altiude pistons unless it was resleeved with new pistons over the years. You can install 3.25" pistons with a new sleeve kit without any machining to the block. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
