Re: 400D water pump rebuild
Posted by Kevin Meier on July 20, 2007 at 16:33:34 from (64.71.85.247):
In Reply to: 400D water pump rebuild posted by John Graham on July 20, 2007 at 14:12:42:
You should have enough packing to put tension on the shaft when the brass gland is tight, and still have room for the notch in the top of the shaft to fit the cross bar. If you are using the rope type and not the pre cut I usually put in around 19 inches.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
