Re: starter wont engage
Posted by Janicholson on July 21, 2007 at 09:04:11 from (71.87.39.51):
In Reply to: Re: starter wont engage posted by matt in Wi on July 21, 2007 at 08:57:03:
If the starter spins instantly (the battery is good and cables are well connected), the only two possible answers are to crank start, or pull start the tractor. DOn't pull start it if not experienced. or Taking the starter out and cleaning the existing drive in solvent, and putting a spray lube on it (if broken parts are found, a new drive is the answer) I like a spray that contains PTFE like TiiFlow. JimN
