Re: How much power is eaten up thru gears?
Posted by Athol Carr on July 21, 2007 at 14:47:19 from (219.89.29.20):
In Reply to: How much power is eaten up thru gears? posted by Farmall MD on July 21, 2007 at 09:33:22:
The gears take some power, some old rough figures were 5% per set of gears. The difference between belt power and drawbar horsepower is the number of gear sets (the F-12 belt has one one set of bevel gears) at least four to the back axles. there is also rolling resistance, with steel wheels the ground is permanent deformed by the rigid wheels ( the ground level behind the wheel is lower than that in front, i.e. permanently climbing up-hill) and the lugs have to be driven into the ground and then lifted out again. With Pneumatic tyres the rolling resistance is considerable reduced the re is less ground deformation though there is the energy lost in tyre flexure. The F-12 was rated 14hp on the belt, so probably produced something like 17hp at the flywheel.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
