Re: Bob M, I need your help
Posted by El Toro on July 22, 2007 at 04:20:27 from (205.188.117.137):
In Reply to: Re: Bob M, I need your help posted by Paul Shuler on July 21, 2007 at 18:55:28:
Since you have a distributor you need battery voltage to the distributor. If the battery is dead and a generator with no output could be the reason it wouldn't start when being pulled. I would recharge the battery and see if battery voltage is present at the starter. Make sure your ground cable is making good contact where its grounded on the tractor. Any paint or rust are good insulators. Hal
