crankshaft pulley center bolt on B farmall
Posted by Curt In Minnesota on July 22, 2007 at 16:22:03 from (69.42.228.172):
In order to use my new engine stand I bought for my B farmall project (where I need to replace bearings in the transmission and any thing else), I see I need to pull the crank shaft pulley. I assume there is a threaded hole at the center so one can pull on a bolt. I not sure I am going to get front end off to inspect it tonight but would like to buy the bolt tomorrow when I go to town. Does anybody have an idea about the size of this bolt and if it is fine threaded? I picked up a new used torque tube since the original was brazed. So I need to take the engine off anyway while replacing the transmission bearings. Thanks for your help. Curt
