Re: PTO lever locked up on farmall 230
Posted by Hugh MacKay on July 23, 2007 at 02:40:23 from (216.208.58.190):
In Reply to: PTO lever locked up on farmall 230 posted by Dan in MO on July 22, 2007 at 19:06:30:
Dan: These are quite simple and you have two possible problems unless something is broken up. First, about 2" back from the pto engage lever is plug with blade type screw end. Behind that plug is a spring and detent device that is designed to hold pto lever either engaged or disengaged. Secondly the actual engagment happens as a result of a hollow shaft sliding on a solid shaft. That hollow shaft is designed so it actually only makes contact with the solid shaft at both ends. If you know or suspect the tractor was parked for extended period, years for example. Rust can build up during that non use as no oil gets up there during that non use. This applies to both sliding shaft as well as the detent. Usually this is just a matter of removing PTO and doing a clean up. Find a spot to park tractor with front wheels about 1' below rears, then you don't need to drain the transmission. Just remove the bolts around the PTO housing and it will slide right out. If it has a belt pulley, best to remove that gear box first, keeps weight and balance a bit better. Don't misplace or loose shims between the two gear boxes.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
