Re: 400D water pump rebuild
Posted by Kevin Meier on July 23, 2007 at 13:56:03 from (64.71.85.247):
In Reply to: 400D water pump rebuild posted by John Graham on July 20, 2007 at 14:12:42:
I use 1/8" packing off of a roll. I grease the shaft before sliding it through the bushings. Also make sure the mating surfaces on the impeller and the bottom end of the center tube are faced off true.
