Re: adjusting valves on H
Posted by El Toro on July 23, 2007 at 17:23:38 from (64.12.116.73):
In Reply to: adjusting valves on H posted by Curtis E on July 23, 2007 at 16:37:09:
You need to remove No1 sparkplug near the radiator and hold your thumb over the plug hole while someone hand cranks the engine until you feel compression against your thumb. Then have them slowly keep cranking until the notch on the damper is aligned with the pointer. Remove your distributor cap and your rotor should be pointing to the No1 plug tower. Then you can adjust these valves counting from radiator end of the engine.
1, 2, 3, 5 then crank the engine until your rotor
points to No4 plug wire. The notch on the damper should be aligned with the pointer and then adjust
4, 6, 7, 8 to .020" Cold. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
