Re: adjusting valves on H
Posted by Wayne in MN on July 23, 2007 at 20:18:21 from (71.13.41.163):
In Reply to: adjusting valves on H posted by Curtis E on July 23, 2007 at 16:37:09:
Valve adjustment process—Farmall 4 cylinder: Firing order 1-3-4-2 1. While slowly turning the engine with the crank, watch when #1 cylinder (front one) exhaust valve closes and #1 intake valve starts to open. That is when the piston is at Top Dead Center (TDC). Note: the timing pointer should be lined up with the I I mark (double line) on the front pulley. 2. Rotate the crankshaft exactly 1 rotation to put the #1 piston at TDC again with both valves closed and ready for adjustment. Adjust the valve to rocker arm clearance so the feeler gauge has a slight drag as you pull it out. (check specifications for correct amount) Be sure to tighten the lock nut!! Note: this is where you can set ignition timing also. 3. With both valves set on #1, rotate the crankshaft ½ turn and #3 cylinder will be in position to adjust it’s valves. 4. One more ½ turn of the crank and #4 valves can be adjusted. Note: the timing pointer will be at the I I mark again. 5. Once more turn the crank ½ rotation and #2 valves can be set. 6. Re-check all lock nuts, install a new gasket, and you are done.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
