Re: w-9 international tractor--1952 My grandpas--
Posted by georgeky on July 24, 2007 at 15:07:21 from (205.188.117.137):
In Reply to: w-9 international tractor--1952 My grandpas-- posted by Brett Nelson on July 24, 2007 at 13:22:36:
Yes they are available. Get your billfold out as they are quite high. Bates Corp has them at 500 dollars per hole. That is piston,rings,sleeve and pins.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
