Re: Super M 12volt conversion
Posted by john d on July 24, 2007 at 18:57:17 from (69.130.180.196):
In Reply to: Super M 12volt conversion posted by Debi Scofield on July 24, 2007 at 13:39:04:
Converted my M, and will do the SM as soon as I find time. Used a WalMart heavy duty battery, Delco 10SI 3-wire alternator, original coil, 1970 Chrysler ballast resistor, all new wires, and a set of halogen lights. Total cost about $120.
