Re: Farmall B switch
Posted by Janicholson on July 25, 2007 at 16:47:50 from (66.173.50.27):
In Reply to: Farmall B switch posted by Dave H (MI) on July 25, 2007 at 16:11:07:
There is a switch on the starter. It is the device the big cable is attached to. There should be a mechanical (pull rod) attached to this switch. If these (and a good battery ground are connected, the engine should spin over (it may not start, but it will turn over.
The other switch is either a mag kill switch that is open when pulled out , and closed (conducting) when pushed in.
If it has a coil and distributor, not mag, the ignition switch is open when pushed in, and closed when pulled out. This switch shuts off electricity from getting to the coil, thus stopping the engine when pushed in.
A wire off of a coil system will keep it from running, but not cranking. A wire off of a Mag system will let it run but be unable to shut it off. Tell us more details. JimN
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
