Re: 806 diesel hydraulics schematic needed
Posted by Randy in NE on July 26, 2007 at 15:05:48 from (204.124.193.191):
In Reply to: 806 diesel hydraulics schematic needed posted by Mark Fisher on July 26, 2007 at 11:13:37:
I have the parts cd with the diagrams on it. It is pretty cluttered so hard to follow. but I can dump it to a pdf file and email it to you. Not sure if the 06 series are anything like the 66 but with the 66 series you just added another block under the seat and piped it back. There is an inside and outside block. You would just need to get an inside one along with some longer bolts.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
