Re: hydraulics on a 454 International
Posted by Fromjb2 on July 27, 2007 at 19:36:13 from (74.111.67.38):
In Reply to: hydraulics on a 454 International posted by Darwin Kurtz on July 27, 2007 at 17:24:24:
Hi Darwin, could be dirt stuck in a valve in the MCV valve. If the tractor has remote hydraulic outlets, operated the lever that controls the remote outlets until you hear the hydraulic relief valve squeal. Sometimes that will blow the dirt out of the stuck valve.
Good luck
JimB
