Re: SOS I need help badly - starter elecrtical problem
Posted by 55 50 on July 28, 2007 at 19:50:19 from (216.114.212.62):
In Reply to: Re: SOS I need help badly - starter elecrtical problem posted by 888 on July 28, 2007 at 14:11:21:
Your next-to-the-last paragraph is incorrect. A ground as you describe it would only have a very low voltage as you say you measure .06V; You will NOT SEE any significant voltage leave a switch if there is a ground at that point!!
