Re: 504 three-point stabilizers
Posted by georgeky on July 28, 2007 at 21:35:00 from (64.12.117.137):
In Reply to: 504 three-point stabilizers posted by Wis. Joe on July 28, 2007 at 18:02:37:
There is a stabilizer kit for that tractor, but I expect it is expensive. They can be made quite easily. Use a piece of channel iron that hangs down from axle the same as the lift arm mount and attach mounting pins to it. The stabilizer itself can be made from a 1 inch water pipe with the ends hammered flat and holes bored in it. For a more detailed plan for this just email me and I will send you some dimensions and pics.
