Re: 340 won't start
Posted by El Toro on July 29, 2007 at 07:38:32 from (152.163.100.203):
In Reply to: Re: 340 won't start posted by upred on July 29, 2007 at 05:24:35:
I would suspect the coil to cause this when it gets hot. If it will start ok when cold then stops after some running is a good indication of a coil. When it stops pull the coil wire from the cap and hold near a good ground while makes an attempt to start the tractor. Need to do this before the coil has a chance to cool. Hal
PS: The condenser would be the cheaper to change first.
