Re: 2 PTO shafts.
Posted by Butch WI on July 29, 2007 at 07:44:42 from (69.179.89.105):
In Reply to: Re: 2 PTO shafts. posted by Bill Brox on July 29, 2007 at 05:36:43:
Bill,
The IH's we have, both PTO's turn at the same time but at different speeds and generally when you pull an implement you only need one PTO shaft to operate it. The newer JD's we have have only 1 output shaft BUT you could remove a snap ring then take out the shaft and put it in the other direction and replace the snap ring. The shaft you removed had a splined center with a 540 RPM on one end and a 1000 RPM on the other. As for when the IH started with two shafts coming out of the rear end I don't know.
Butch
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
