Re: hydraulics on a 454 International
Posted by Bernard le mécano on July 29, 2007 at 08:37:13 from (207.134.205.166):
In Reply to: hydraulics on a 454 International posted by Darwin Kurtz on July 27, 2007 at 17:24:24:
Hi, under the seat it have a valve (unload valve) with a big plug in front. Remove the plug and pull the spool, make sure to replace in the same way. It have a small orifice, blow with air. Replace the spool then the plug. Start the engine and check the lift system. Bernard le mécano Québec Canada
