Re: rebuilding disc brakes on my farmall 300
Posted by Farmer Bob on July 29, 2007 at 12:02:21 from (71.53.71.71):
In Reply to: rebuilding disc brakes on my farmall 300 posted by farmall300 on July 29, 2007 at 11:41:37:
It's a pretty straight forward job once you get the outer housing removed so you can see the parts involved. If you find a greasy mess inside which normally indicates a leaking inner seal (And possibly a bad bearing), the job gets more complicated. Investigate your brakes and then come back with your findings. Someone will surely walk you through the finer points. If you find no grease/oil inside the housing, it is just a matter of removing the brake discs and the actuator, taking apart the actuator so you can clean up the ramps where the steel balls reside, inspect the balls for smoothness, sand down the ramps, replacing the balls if necessary, replace the discs and inspect the mating surfaces of the housings where the discs make contact. You may get by with just some minor sanding. Reassemble everything and adjust per the manual. You'll never know unless you try it yourself.
