Re: Regular Clutch Removal
Posted by kevin (LA-CA) on July 29, 2007 at 12:04:57 from (75.84.179.35):
In Reply to: Regular Clutch Removal posted by Barry Ingraham on July 28, 2007 at 19:20:01:
My experience is similar to Jimmy's. The service manual says the clutch cover and clutch come out as a unit. I was able to remove the cover to access the clutch itself. A wire brush in grinder to remove rust on the 3 large guide / drive pins & liberal amounts of WD40/PB Blaster etc. Carefully pry to remove the clutch. Phew do the old mouse nests stink!
I drilled out the lining rivets, carefully pryed off the linings removed rust from driven and driving plates & reassembled. Works OK for a tractor that will never get more than 1 hour running / year.
Good luck. kevin
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
