Re: Super C rear axle seal leaking
Posted by Haas on July 29, 2007 at 17:22:49 from (12.65.36.125):
In Reply to: Super C rear axle seal leaking posted by Larry in GA on July 29, 2007 at 17:07:32:
Replacing the outer seal is as you describe. However, likely it will not cure the problem. The outer axle bearing is only supposed to be lubed by the grease fitting provided. There is another inside seal on the inside end of the axle that is supposed to keep transmission oil out of the axle carrier. So...likely that seal is leaking oil as well which is getting into the axle carrier and then to the outer seal and leaking out. Replacing the inner seal is a bigger job, as you have to pull the axle out of the bull gear and remove the axle carrier to get to it. I replaced the outer seal on my C axle several years ago. It was better for a while, but now it is leaking again.
