Re: Super C rear axle seal leaking
Posted by georgeky on July 29, 2007 at 17:22:51 from (205.188.117.137):
In Reply to: Super C rear axle seal leaking posted by Larry in GA on July 29, 2007 at 17:07:32:
Larry, there is a seal on the other end of the axle that keeps the oil in the rear end housing. It is leaking past it and out the other end. You can just put the outer seal in and may stop it, but it isn't the trouble. The inner needs replacing. The outer is only to keep grease in that end of it.
