Re: getting in to antique pulling advise?
Posted by ChadS on July 30, 2007 at 06:29:56 from (4.224.78.134):
In Reply to: getting in to antique pulling advise? posted by jcarter on July 28, 2007 at 11:09:33:
Find you a M or a SM. The SM has the best engine upgrade option for that series and allows you to put more weight on the tractor for better leverage VS a heavier 400-450. A M can get down to 4500 with pressed steel rims, a 400-450 wont get below 5000 without it being stripped down beyond what a M can. So if you got a 4500# M and you wanna pull 7000#,,, thats quite a bit of added weight to get it balanced out. JMHO, Chad
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
