Re: 400 overheating..
Posted by Bob M on July 30, 2007 at 12:10:48 from (151.190.254.108):
In Reply to: 400 overheating.. posted by Jesse on July 30, 2007 at 11:20:37:
Bend a piece of soft 1/4" copper tubing into a "L" shape and attach it to the end of compressed air gun. Then use the tube to direct air backward thru the radiator - ie. from the fan side toward the grille. (If you've been bush hogging very long you'll be amazed how much chaff, etc. this will dislodge from the core!)
Also while you are at it check for a slipping fan belt, scale build-up inside the core tubes and a stuck thermostat!
