Re: 560 Diesel....runs for a bit then quits
Posted by Hugh MacKay on July 30, 2007 at 14:25:56 from (209.226.106.105):
In Reply to: Re: 560 Diesel....runs for a bit then quits posted by Don Dittmar on July 30, 2007 at 05:18:19:
Don: I guess this is a case of terminology differences, the vane pump device you speak of will not suck fuel from below the engine, or at least my 560 and 656 wouldn't. The fuel had to flow there by graviety. I had a neighbor used a 282 as a stationary engine, same Rossa Master pump as my 560 and he had to use an electric transfer pump, from a tank almost level with crank shaft. I had a John Deere forestry skidder, fuel tank back of articulation point and below the engine It had almost identical Rossa Master to my 560 and 656, but had to use a cam shaft driven fuel transfer pump. Those last two are what I was refering to as a fuel transfer pump.
