Re: Super C rear axle seal leaking
Posted by Haas on July 31, 2007 at 09:26:05 from (12.65.0.71):
In Reply to: Re: Super C rear axle seal leaking posted by Larry in GA on July 29, 2007 at 18:56:33:
YOu can't get to that inside seal without removing the axle carrier from the transmission housing. I've not done this, but I believe the bull gear retainers have to be taken off first and then the axle and axle carrier will comee off as a unit. Take care to not let the bull gear drop down hard when the axle comes out of it. Block it up some how to keep it from falling on the bottom of the transmission case. I'm with George regards the transmission top. I've had the PTO unit off my C and I don't see how you could ever get the bull gear on and off the axle through that hole. Maybe it can be done, but I think it would be much easier to just pull the top off the transmission.
