Re: H hydraulics question
Posted by Nat 2 on July 31, 2007 at 11:50:28 from (64.80.110.50):
In Reply to: H hydraulics question posted by J.C. on July 31, 2007 at 10:33:49:
You got it. That is your basic Farmall "Liftall" system, also referred to as "belly pump" due to the fact that the pump is located in the belly of the tractor. It gives you one-way (power up, gravity down) hydraulics by pulling the lever on the right side.
There are three ports total, two on the right, one on the left. The left port and front right port provide pressure at the same time. The rear right port provides pressure after a delay.
If you need power-down for an implement, you will need to add a two-way valve to the system. Do not hook the two hoses from a modern hydraulic cylinder to two ports on the tractor, assuming that you'll get two-way hydraulics. That is a sure way to damage the system.
