valve clearance hot vs cold
Posted by sgtbull on July 31, 2007 at 19:49:02 from (4.245.73.126):
Okay, I realize that valves are usually set "hot", on most tractors, because there is a difference in the clearance of hot and cold valves.... but my question is, for an initial setting, should you set the valves a thousandth or so less, or more, to compensate for the dimension change? I know heat expands metal, and it would seem that the "hot" clearance would be less than the cold clearance, making me think if it said, say, .015 hot, I should set it at say, .016 or .017 cold.... is my logic right?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
