Re: F-12 cam gear?
Posted by Farmall MD on August 01, 2007 at 01:09:16 from (205.188.117.137):
In Reply to: Re: F-12 cam gear? posted by John M on July 31, 2007 at 18:25:02:
John, reread the post. I want to mill a keyway in the CAM, not broach a keyway in the gear. And also, if I line up marks, cam will be 180 deg off. Doug N
