Re: operate two way cylinder with Lift all pump
Posted by john d on August 01, 2007 at 17:26:43 from (69.130.180.196):
In Reply to: operate two way cylinder with Lift all pump posted by Brad in WI on August 01, 2007 at 16:41:49:
Connect a hose from the front port on the left side of the tractor, or the only port on the right side of the tractor to the end of the cylinder that makes your equipment lift. Remove the hose from the other end of the cylinder and install a "breather" that will let air enter that end of the cylinder. These are commonly available from any hydraulics supply place.
The hydraulic pressure will lift the equipment, and gravity will lower it when you push the hydraulic control rod all the way forward. If the tractor cannot lift the load, a larger diameter cylinder will help.
